Stripping Target SuperClear 3000 http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=930 |
Author: | rlabbe [ Wed Feb 02, 2005 2:46 am ] |
Post subject: | |
What's the best method for stripping waterborne products? I've heard of the heat lamp/gun method to soften the finish, and then peel it off with a razor blade, and I assume there are chemical means. I'd really rather not sand the stuff off. Any advice? P.S. I used Acetone and a scraper to remove the finish off of the B&S, and it worked, although the acetone also attacked where I filled a few gaps with stick shellac. However, the thought of taking a scraper to the cedar top is daunting, but so is using a heat gun on it. |
Author: | Michael Dale Payne [ Wed Feb 02, 2005 4:11 am ] |
Post subject: | |
A warm wet towel and a puddy knife. I would not use a chemical stripper. It could damage plastic binding and purflig and change the color of wood. Most waterborne lacquers will soften quickly under a warm wet towel and can be peeled right off with little problems. Don' ask why I know this ![]() |
